Home › Forums › Products › Stompboxes › Arturia Beatstep Sequencer › Reply To: Arturia Beatstep Sequencer
#140232
BarneyBrown
    Excellent. It looks like the calibration procedure has cured the 2v issue – as I now have access to the full range allocated to the Hot Switch. Thanks a lot Dan – that’s brilliant!
    So after calibrating, it looks like the BeatStep divides/maps this range into 16 steps or so. If I use the sequencer to control MIX for example (with a range from 0 to 100) I can access multiples of 6 or 7. Alternatively, if I use a Pitch parameter I can access two whole diatonic octaves or 1.5 chromatic octaves. This is fine for most applications I planned to use it for.
    Not sure how this sort of resolution compares to the Electro-Harmonix 8 Step. Brock, any ideas?
