Home › Forums › Products › Stompboxes › H9 Volume pedal function › Reply To: H9 Volume pedal function
September 4, 2015 at 5:57 pm
#140421
forfunk49 wrote:
I want to have a preset on my h9 that acts as a simple volume pedal for country swells and slide playing etc…. Seems like this should be a real simple setting but I can't seem to find an algorithm….
So, you want an H9 preset that behaves as a simple volume pedal and nothing else? And you want to use your expression pedal to control the volume? With the latest H9 release you can make the expression pedal control the volume on any preset. In H9 Control when you're looking at the preset, you click on the More button and click the button "EXP controls output volume". If you don't want the preset to alter your tone, a good candidate for this would be an EQ Compressor preset. You could set the EQ to flat… But really you could do this with any preset…
