Home › Forums › Products › Stompboxes › Strymon Dig sounds? › Reply To: Strymon Dig sounds?
Nice post, Brock.
Just to add a little to it… The Filter Pong Algorithm on the H9 and TimeFactor is a series delay. Delay A feeds Delay B.
This is a little known Eventide “Easter Egg”, so to speak! Check it out if you have the chance.
Thank you for that info. I never tried it because I assumed I had to have this hooked up in stereo to use ping pong mode. So if I put it in ping pong mode but only use 1 in and 1 out, it will be a series delay?
Brock, while I did not use your exact numbers, I did pick two long delay times that were separated by the golden ratio. I dialed a fair amount of feedback and added some low pass. This is whatI was looking for!
Thank you both again for taking the time to post.
