Home Forums Products Stompboxes Pre/Post option and killdry issue Reply To: Pre/Post option and killdry issue
#140660
    Pre-post with killdry is designed to be used with pre before an amp and post in a parallel effect loop – if killdry operated on the pre signal, it would mute everything. Silence is golden….
    Nothing to stop you using it in other ways, but this is why it works the way it does.
