Home Forums Products Stompboxes Pre/Post option and killdry issue Reply To: Pre/Post option and killdry issue
#140683
    David Giacomini wrote:
    I assume the bypass is common to both the Pre/Post routed signals, with an inevitable digital conversion stage in the pre routing path if the post is in Killdry mode set for parallel use.
    You are correct – the bypass is common to both channels. Obviously, when it was designed, a feature like pre/post was not anticipated, so it does not allow for it.
