Home › Forums › Products › Stompboxes › Saving the mix level on the Space › Reply To: Saving the mix level on the Space
September 29, 2015 at 5:44 pm
#140772
blackvomit wrote:
I understand how to save a preset. After saving a preset, the mix level seems to be universal. I was wondering if it was possible to have a set mix level for a preset
The mix level is only universal if you have the Global Mix setting enabled; if you want to use the mix level saved with the preset, you'll want to turn that setting off.
