Home Forums Products Stompboxes TimeFactor vintage delay issue Reply To: TimeFactor vintage delay issue
#140776
boyce89976
    No, I keep the bit rate at 20 for most of my vintage delay patches and confirmed that’s where it’s set when the distortion started. It’s a”whoosh” type of sound, instead of the normal repeat. I also re-initialized it after loading the new firmware, but I’ll try that again.
    jeffschumacher wrote:
    boyce89976 wrote:
    Ever since loading the newest firmware, I’m having an intermittent problem with my TF when using the Vintage Delay setting. Problem is that the repeats will sometimes become very distorted, lose any articulation and go to what seems like 100% mix, when mix is set to 20%. It sounds like a short toilet flush. Inputs are not clipping according to the LED on the TF (it’s not even lighting up as I run it line level in the effects loop of my amps). Any ideas what’s wrong? I use the Digital, Tape, and Mod delays frequently and don’t notice the issue with those.
    When you updated your unit, did you re-initialize it afterwards?  It’s recommended that you re-initialize after installation. Be sure to back up your presets before you do!
    As far as the distorted sound goes.. with the Vintage Delay algorithm, you can select the number of bits of resolution which result in a distorted sound.  Could that be what you are hearing? If you adjust the BITS knob does the distorted sound go away?
