Home Forums Products Stompboxes Saving the mix level on the Space Reply To: Saving the mix level on the Space
#140787
blackvomit
gkellum wrote:
blackvomit wrote:
I understand how to save a preset. After saving a preset, the mix level seems to be universal. I was wondering if it was possible to have a set mix level for a preset
The mix level is only universal if you have the Global Mix setting enabled;  if you want to use the mix level saved with the preset, you'll want to turn that setting off.
Even with “global” set to off the mix level still seems to be universal
