Home › Forums › Products › Stompboxes › Saving the mix level on the Space › Reply To: Saving the mix level on the Space
#140790
gkellum
    Hm… Do you have an expression pedal or MIDI controller hooked up to your Space?
    Could you try disconnecting anything of that nature that might be connected to your Space and saving a preset as described above, changing the preset, going back to your saved preset, and seeing if it has the mix level that you saved?
