Home Forums Products Stompboxes Strings Reply To: Strings
#140856
    Here are a couple of presets that I posted earlier here.  More of a string ensemble-type of effect.
    Expression Pedal Heel = TONE -15
    Expression Pedal Heel =  SLURM 35
    Expression Pedal Toe =  TONE 35
    Expression Pedal Toe =   SLURM 100
    HotSwitch OFF = LENGTH 2000 mS
    HotSwitch OFF =  RISE 0
    HotSwitch ON = LENGTH 0mS
    HotSwitch ON =  RISE 50
    Expression Pedal Heel = B-PITCH 2400c
    Expression Pedal Toe =  B-PITCH 700c
    HotSwitch OFF = PITCH-DECAY 100
    HotSwitch ON =   PITCH+VERB FRZ
    But with 2 H9 Maxes, you could also split up the ‘string’ and ‘shimmer / octaves’ into two separate presets (in series).  For the initial preset, I’ll use something like the following image.  The expression pedal and HotSwitch assignments give a variety of ‘scrape’ and attack characteristics.  Or go with something like the MangleVerb preset below that.  Fixed ‘attack’, strictly for staccato work, and with a little expression pedal ‘wobble’ to fill out the depth of effect with modulation.
    Expression Pedal Heel = RISE  99
    Expression Pedal Toe =  RISE   0
    HotSwitch OFF = LENGTH  150 mS
    HotSwitch OFF = TAPS  32
    HotSwitch ON =   LENGTH  250 mS
    HotSwitch ON =  TAPS  64
    Expression Pedal Heel = WOBBLE  0
    Expression Pedal Toe =  WOBBLE  40
