Home Forums Products Stompboxes Getting a time factor or a timeline? Reply To: Getting a time factor or a timeline?
#141026
The TimeFactor.
I own both units and the only difference between them is that the TimeLine has a warmer sound, THAT’S ALL.  Its user interface is clunky, you have to rely on bars on the display to know what you’re adjusting and, to my knowledge, it doesn’t have a pc editor that I know of.
The TimeFactor, on the other hand, will let you run dual delays in any algorithm, has a better physical layout, less submenus and has a better pc editor and a bigger display that uses real numbers to let you know what you’re adjusting instead of little bars.  With the newer firmware, you can also benefit from the routing options.  Lastly, it’ll play nice with the Space you currently own.
