Home › Forums › Products › Stompboxes › Cant access the H9 input levels › Reply To: Cant access the H9 input levels
#141116
gkellum
    The input levels moved.  I believe that the latest H9 user manual was updated with that change.  But in any case the input levels are under system settings now.  If you're configuring them on the H9 itself, you'd enter system settings, go to utils and then to INGAIN as described in the user manual.  You can also configure this setting in H9 Control under the Pedal Settings section.
