Home Forums Products Stompboxes H9 Hiss in front of amp – Video Reply To: H9 Hiss in front of amp – Video
#141229
I found out something interesting. The hiss is only noticeable when the pedal is in pre/post configuration. I mean when inputs and outputs 1 and 2 are used. Otherwise the hiss is gone. If I put h9 in front of my amp in normal configuration (using only input 1 and output 1) I am not able to hear the hiss using all my amp channels.
I realized that in this pre/post configuration the hiss is gone when I swicth off the effect loop
Maybe there is a bug or something you could fix with an update….
What do you think?
