Home › Forums › Products › Stompboxes › Pitch and Pan Modulation on H9 › Reply To: Pitch and Pan Modulation on H9
The MicroPitch, H910/H949, HarModulator, and TremoloPan algorithms immediately came to mind for slight pitch modulation and/or panning. There are some others that could fit the intent. But I think that the Vibrato algo would be the most efficient algo, using a single H9. That is, if you want the panning and pitch changes synchronized, with the potential to also sync them to the incoming delay-only signal. I would think you’d want Kill Dry ON in the system settings for the parallel loop.
An an example, this preset below is a little deep, for demontration purposes. A careful balance of INTENSITY and DEPTH will get you all the way from subtle & barely audible, to drunk & seasick. WIDTH spreads the pitch modulation from mono to stereo at the rate set in SPEED. The triangle SHAPE is smooth and linear; you might try SQUARE or RAMP for hard-snapping to delay times.
I have DEPTH MOD and SPEED MOD from 1 to 50 over the expression pedal sweep. It will fold in some RANDOM rate increases over the 1.00 Hz. SPEED. If you really want subtle (but noticeable), hit the SLOW/FAST Perfortmance Switch.
This next preset has shallower modulation, at rates closer to finger & in-fret vibrato. Again, INTENSITY and DEPTH balancing is your friend here. The VINTAGE vibe comes across as more “phase-y” (although certainly not as much as RETRO, and panning isn’t available to that). Expression pedal mapping spans the range of common vibrato SPEED. SLOW/FAST is also great for the ramping to and from the programmed SPEED. It adds variety and interest, and can disguise the periodic LFO waveforms.
