Home Forums Products Stompboxes Updating H9 for CrushStation and Pre/Post Routing Options Reply To: Updating H9 for CrushStation and Pre/Post Routing Options
#141288
gkellum
    air621 wrote:
    I set my H9 up for the pre/post setting. So far it's working great, though something happened and I'm not sure how. I got it set up and then activated the tuner. The signal was coming through despite being set to mute. As well, the tuner was having a real hard time tracking notes. I turned it off and on and it worked fine, but I really hope this doesn't happen during a gig
    My colleague, Nick, was recommending that people reset their system settings after updating if it caused no great inconvenience to do so.  For some reason with this update in particular, people's system settings were getting messed up which was causing odd H9 behavior.  That may explain the strange tuner behavior you were seeing.
