Home Forums Products Stompboxes Uncontrollable squealing with H9 Reply To: Uncontrollable squealing with H9
#141395
    If your Pre/post connections are not set up right, it can end up fully or partially connecting an output to an input, which will cause feedback. Nothing we can do about it. It will be worse on distortion programs because they add effective compression.
    Have a good look at your connections, with help if necessary, and try and spot the feedback path.
