Home Forums Products Stompboxes H9 inputs clip when in FX loop of amp Reply To: H9 inputs clip when in FX loop of amp
#141510
    It sounds like your effects loop output is too hot for the H9. Check for a level control on the amp.
    Otherwise, if you've set the H9's input gain to its lowest level, you will need a suitable pad or attenuator. Simplest way is to have a tech wire up a few resistors to make an attenuating lead.
