Home Forums Products Stompboxes Missing global Output Level on H9 Reply To: Missing global Output Level on H9
#141582
gkellum
    kokomiko wrote:
    Or is there any trick I do not know?
    Well, you know that you can assign the output gain to an expression pedal or MIDI right?  But this only takes you up to unity gain.  It sounds like you want to boost the global output level…  You could turn the preset output gain up in each preset you use…
