Reply To: Timefactor expression pedal input not working
Home Forums Products Stompboxes Timefactor expression pedal input not working Reply To: Timefactor expression pedal input not working
#141589
gkellum
Well, if you haven't done so already, you should try resetting the TimeFactor's system settings by turning it off and then turning it on again with the right footswitch and the algorithm selector knob pressed.  This will wipe out any setting changes you made, but it won't affect your presets.  For whatever reason a lot of people have run into problems with this v5.2 upgrade that can be cleared up just by doing that.
