Home Forums Products Stompboxes Modfactor Midi clock problem and upgrading via USB Reply To: Modfactor Midi clock problem and upgrading via USB
#141612
gkellum
    Lou Bourbon wrote:
    The clocking issue though concerns me. If I can reclock the pedal by tapping it, why can't engineers reclock the pedal to the incomming midi clock every 4 beats (or so)? Why even have a midi clock option at all if the clock won't work correctly due to drift? This seems really strange to me….and if the clock feature will have the same problems on the Time Factor…why is something like an arpegiator even included if it will not stay in time with a MIDI clock. This is very worrysome to me…
    You mean the HarPeggiator from PitchFactor?  Do you have that too?  That has different MIDI Clock behaviour actually…  It reads directly from the MIDI Clock and uses that to drive the playhead…  So, it won't drift…
    In any case please update and let us know how you're getting along…  It could be that the MIDI Clock filter is going to give you the behavior you want…
