Home › Forums › Products › Stompboxes › Modfactor Midi clock problem and upgrading via USB › Reply To: Modfactor Midi clock problem and upgrading via USB
November 23, 2015 at 8:51 pm
#141615
Lou Bourbon wrote:
I upgraded to the 5.2.0 version and lost any ability to have the pedal recognize "Clock In" commands. ???
I'm trying the 3.5.0 version now.
Did I upgrade to the wrong version before?
No, v5.2 is the best version to upgrade to. After upgrading, I'd recommend clearing your pedals system settings by turning it off and turning it on again with the right footswitch and the algorithm selector knob pressed. Then, go into the system settings and double check that the MIDI settings are correct. All the MIDI clock stuff has been tested with that release and you shouldn't have any trouble using it.
