Home Forums Products Stompboxes H9 inputs clip when in FX loop of amp Reply To: H9 inputs clip when in FX loop of amp
#141753
    [/quote] Please explain?. You can trim the input gain positive, why not negative also?[/quote]
    I understand your puzzlement, but this is a hardware feature of the A/D converter – it will boost but not cut. Even if it did, the front end would clip first.
    This is obviously not a great design feature, but alas not easily changed.
