Home › Forums › Products › Stompboxes › Expression pedal to H9 › Reply To: Expression pedal to H9
January 7, 2016 at 9:37 pm
#142085
rsvmark wrote:
Final update on testing- I have an option to go TRS to TRS and have disconnected the aux switch. Finally the top down value is 100 but the heel down value is 92….
Could you try recalibrating the expression pedal to see if that helps? To calibrate the expression pedal in H9 Control, click on the Pedal button in the bottom menu bar, go to General Settings, and go Pedal Calibration Disabled. Disable it and then enable it to make your H9 forget the previous calibration setting. Then, with it enabled, move the expression pedal from heal to toe, and once you are finished calibrating it, disable pedal calibration again to lock out any further changes.
