Home › Forums › Products › Stompboxes › H9 Shimmer – Pitch decay etc › Reply To: H9 Shimmer – Pitch decay etc
Here’s something to experiment with. DELAY at maximum, reverb at minimum, plenty of LOW-, HIGH-, and MID-DECAY. The pitch shifters mirror perfect 4ths, and PITCH-DECAY loops everything around at 100.
HotSwitch programming: Switch LOW-, HIGH-, and MID-DECAY to 0. That leaves a touch of ambient reverb (nothing else).
The expression pedal here sweeps through the narrow range of PITCH-DECAY: 100, PITCH: FREEZE, and PITCH+VERB: FRZ. One cool performance technique is to adjust the upper range to ‘just barely’ on PITCH+VERB: FRZ . Then you can use the majority of the pedal travel between PITCH-DECAY: 100 and PITCH: FREEZE. Only the top 5-10% of the expression pedal will kick in PITCH+VERB: FRZ. Makes it easy to selectively add to (and edit) the ‘frozen infinite’ background.
