Home Forums Products Stompboxes Mapping Pitchfactor presets to MIDI notes Reply To: Mapping Pitchfactor presets to MIDI notes
#142224
gkellum
    pigsnoot wrote:
    I want to switch through presets using a simple stand alone cheap midi keyboard…
    Is this possible? Are preset changes strictly controlled by Program Changes or can they be controlled by CC's or Midi Notes?
    I don't think this is going to work like you might want it to.  PitchFactor can't be controlled by MIDI notes.  You can assign MIDI CCs to control various pedal functions.  For example you can assign MIDI CC 23 to increment the preset and a MIDI CC 24 to decrement the preset; most people are hooking this up to MIDI footswitch pedals that are sending MIDI CCs when pressed.  If you want to load particular presets when a particular switch is pressed though, you need to use MIDI program change messages for this.
