Home › Forums › Products › Stompboxes › How to audio-connect two H9 considering PRE/POST routing? › Reply To: How to audio-connect two H9 considering PRE/POST routing?
#142336
dedeman wrote:
I am looking for buying two H9 and want to use them both with one amp(loop), using the four cable for PRE/POST routing.
  1. What is the way to connect them in series?
  2. What is the way to have them in parallel?
  3. Could it be both?
Can anyone share their example of usage?
Thank you.
Hi there,
I use 2 x H9s and run them in series with each other, both in the mono loop of my amp. I think from memory mine is set up:
H9 #1 :
Output 1 -> Input 1 on H9#2
Output 2 -> Input 2 on H9#2
Amp FX loop send –> Input 2 on H9#1
Guitar (or earlier pedals) –> Input 1 on H9#1
H9 #2 :
Output 1 -> amp input (or later pedals in chain)
Output 2 -> Amp FX loop return
Input 1 comes from Output 1 on H9#1
Input 2 comes from Amp FX loop send
