Home › Forums › Products › Stompboxes › MIDI help please! › Reply To: MIDI help please!
February 2, 2016 at 10:49 pm
#142385
Gav RL wrote:
Right now I'm confused. What I'm saying is that I load a preset with the foot switches on the Space.
Sorry – my fault. I had assumed that you were using MIDI from Ableton..
In that case, you can set up the XMT and RCV MIDImaps so that you can load an H9 preset when you load a Space preset. But, if you want (as you do) to pass the MIDIclock, it will also pass the Program Change messages, so you should set the Space and H9 to the same MIDI channel, which should be different from the one your looper uses. Then. I think, you'll be good to go.
