Home › Forums › Products › Stompboxes › PC connection VIA bluetooth › Reply To: PC connection VIA bluetooth
February 10, 2016 at 2:02 pm
#142505
I am using an Asus USB-BT400 bluetooth 4.0 dongle, but could not get it to work with the supplied Broadcom bluetooth stack. Deinstalled the bluetooth stack and used the “Bluetooth Driver Installer” utility and that did the trick for me. It’s worth a try…
You can find the Bluetooth Driver Installer on http://bluetoothinstaller.com. Select the 32bit or 64bit installer based upon your system.
