Home › Forums › Products › Stompboxes › aux switch tuner › Reply To: aux switch tuner
#142585
gkellum
    tojoe wrote:
    So I just got a Boss FS7 switch, which I understand is dual, and momentary, I also have a Mission Exp pedal which Ive been using…Id now like to combine the exp pedal and the aux, I''m using a stereo cable for the pedal and it wks, I have a stereo that breaks out into a ring and a tip ends.what can I acheive with this set up….exp pedal…and an up down Fs7 dual switch or is down and tuner toggle possible…my main thing is how do I get both wking independently…been finding this aux thing frustrating…
    When you're using an aux switch and an expression pedal simulataneously, you can only use a single aux switch.  There's a help document in the H9's documents & downloads section that gives advice on how to use an aux switch and expression pedal simultaneously:
    https://www.eventideaudio.com/support/downloads/using-both-aux-switch-and-expression-pedal-h9
