Home › Forums › Products › Stompboxes › One Control OC10 > H9 Core > EVH5150iii50watt › Reply To: One Control OC10 > H9 Core > EVH5150iii50watt
February 17, 2016 at 9:33 pm
#142600
If you set up the H9 as "MIDI Thru", and wire it just as you posted above, it should work fine. Just make sure your MIDI receive channels are different between the EVH head an the H9 and you should be good to go.
