Home › Forums › Products › Stompboxes › H9 – problem connecting & syncing to DAW › Reply To: H9 – problem connecting & syncing to DAW
March 7, 2016 at 2:41 pm
#142817
Michelle911 wrote:
So with everything plugged in USB and only Control running, should I not be able to connect a midi device? Everything else is the same tho, Win7pro 64.
Do you mean with everything plugged in USB and only Control running should you not be able to connect a MIDI device that communicates with ths H9? Or are you saying the H9 Control is somehow capturing your MIDI devices and not allowing them to be used by other applications even though they shouldn't be being used by H9 Control at all to communicate with the H9?
