Home › Forums › Products › Vsig and Preset Development › Vsig Problems (Eventide DSP4000) › Reply To: Vsig Problems (Eventide DSP4000)
March 13, 2016 at 4:41 pm
#142875
You will need to run it on your 32 bit emulation, as the program is simply not compatible with 64 bit windows programs. Inside of the folder, there is a file entitled “sigdb400.sbs”. If your DSP4000 is any other version than 2.158, delete this file and use the MIDI-> get database function to pull the database from your 4000.
Make sure to download all five files, and place them all in the same folder.
https://www.dropbox.com/sh/44rrzojsqyw8ifx/AAC96Fjq3-lCT-QrFbM1eXeUa?dl=0
Hope that helps!
