Home Forums Products Stompboxes Crosstalk / Feedback Issue Reply To: Crosstalk / Feedback Issue
#142967
wedelich
    Your understanding is correct.  If the H9 is in Pre/Post mode and your preset is set and saved at Pre, H9 i/o 2 should pass the signal unchanged.  A few questions to get started:
    1. Is your amp's loop serial or parallel?
    2. Does this occur with any other algorithms on H9, or is it exclusive to Phaser?
    3. Is the feedback a quick burst, or is it just constant once you engage your loop?
