Home Forums Products Plug-Ins Blackhole, In/Out and Live Reply To: Blackhole, In/Out and Live
#143019
tlongabaugh
    Hi-
    Thanks for bringing this to our attention, I've been able to reproduce it here in AU and will look into a fix. Is it indeed the AU version of Blackhole that you're seeing a problem with? If so, you should be able to use the VST version without issue, that version appears to be fine.
    -Tom
