Home › Forums › Products › Stompboxes › H9 Aux Switch and Expression help/ideas/setup needed please › Reply To: H9 Aux Switch and Expression help/ideas/setup needed please
April 18, 2016 at 9:56 pm
#143202
KCStratMan wrote:
By the way, i have been using a Mission Engineering 25K expression pedal with H9s for over a year and it works perfectly with no calibration. The dual output model will also sweep two devices at the same time.
It seems that pedals that work on their own cnnected to the exp socket don’t necessarily work when also used with a footswitch. I’m using the recommended Hosa splitter cable. I’ve got a Line 6 EX 1 coming and hoping it’s ok to use with the footswitch.
