Home › Forums › Products › Stompboxes › H9 Eq Compressor. Adding sustain › Reply To: H9 Eq Compressor. Adding sustain
May 19, 2016 at 1:36 pm
#143396
You should be able to simply turn the Compression knob up pre or post EQ. You might also want to juice up certain frequencies using the EQ to pull them out for solos.
