Home › Forums › Products › Stompboxes › Time factor going creasy – earth porbem ? › Reply To: Time factor going creasy – earth porbem ?
#143416
    This could be a bad pot, but is more likely to be a fault in the cable between the internal boards.
    If your unit is under warranty, you should send it in.
    If not, first have a technical friend take the top off and "wiggle" this cable to see if just needs plugging in better, or if the cable itself is faulty.
