Home Forums Products Stompboxes Ernie Ball as expression pedal for TomeFactor : logarithm curve ? Reply To: Ernie Ball as expression pedal for TomeFactor : logarithm curve ?
#143454
    The stompbox doesn't care (as long as the pot is around 25k).
    You may care, if the pedal response is wrong. It may vary from effect to effect, depending if you are trying to control a linear function or a log function.
    I would suggest that you not worry too much, and see how it works in your situation.
