Home Forums Products Stompboxes Whammy, bend up effect help Reply To: Whammy, bend up effect help
#143611
    There are a couple of approaches you can take.  The first would be PitchFlex.
    You’ll need something [ aux switch, expression Pedal, or MIDI ] to trigger the pitch bend.  The advantages to using an actual switch for FLEX are the individual GLISS and SHAPE adjustments.  With an expression pedal, you’ll have to attempt that kind of control with your foot.
    You can also route a second aux switch to expression [ “Set expression pedal value (aka HotKnob value)” in H9 Control app ].  The 2nd switch will instantly ‘hammer-on’ to the pitch-shifted notes, without any glides or shaping.  When it’s triggered, this 1st preset glides up from whatever you’re playing.
    Another way is to trigger the glides with your input levels.  That could be your playing techniques, volume knob, etc.  The HarModulator – under envelope control – can sound a little unnatural when it drops back to unison pitch (the input level drops below the threshold).  It’s best to palm-mute your strings the instant before you need to trigger a bend up.  And keep the MOD SENSitivity high to keep the ENVELOPE SHAPE engaged.
    This second preset starts two semitones below your input, and glides up to unison when it’s triggered.
