Home Forums Products Stompboxes Updating H9 for CrushStation and Pre/Post Routing Options Reply To: Updating H9 for CrushStation and Pre/Post Routing Options
#143631
    JegFolay wrote:
    Why did you come with this great option of Pre/Post positioning and not thinking of setting In1 and In2 level gains separately in that only case?
    Actually I have the Post (In2/Out2) H9 set in an FX loop. But this loop level is preset and it clips nearly systematically In2 whereas In1 (direct guitar) tops around -20dB.
    The trouble comes only for the (clipped) sound going into the H9/Post Input, as my preset loop provides a good level regarding the overall output, and the poor level that may go into In1 (but that's not quite the problem for me).
    The hardware design was done WAY before we thought about adding the pre/post feature.
    The H9 is designed for guitar inputs – if you feed it from a hot effects loop it will overload the front end, meaning no gain controls or software would unclip it. Sorry.
