Home Forums Products Stompboxes CC Set parameter controlling mix and other params Reply To: CC Set parameter controlling mix and other params
#143632
JCR
    nickrose wrote:
    Thos is fixed in the next release, due on a month or so.
    Sorry nickrose, the midi timing fix for sending CC’s after a PC does not work for all algo’s. Yes, there are some algo’s now you can send two midi CC’s after a PC to set parameters, but I have found several algo’s that still does not process CC messages after a PC.
    The ones that still not process CC’s after an PC that I have found so far just after a quick check are: Tremolopan, Chorus, Phaser, Flanger, vibrato, q-wah, undulator, tape echo, digital delay, vintage delay and mod delay! I have not checked all algo’s, no time…
    For all named algo’s I have send a PC to select the preset and one CC message to set parameter 1 to 0 (zero) and that failed. Only the preset was selected, no processing for parameter 1, it was as it was saved.
    The algo’s that past the test so far are: micropitch, rotary, ultratap, hall.
    So it seems the midi timing is still not ok for a lot of algo’s after init. I realy hope this will be fixed a.s.a.p…
