Reply To: Studio One 3, OS X to Windows 10 projects, plugin not found
Home Forums Products Plug-Ins Studio One 3, OS X to Windows 10 projects, plugin not found Reply To: Studio One 3, OS X to Windows 10 projects, plugin not found
#143776
tlongabaugh
Hi-
It looks like you are using the Octavox AU on OSX, but VST on Windows, is that correct? It doesn't look like you have the Octavox VST installed on the OSX side, so my guess is that Studio One is not able to match the plug-in between the two formats when going between Windows and OSX. I'd make sure you are using the Octavox VST on the OSX side.
If my guess is correct, on OSX you can save your old settings from the AU as a preset, change to the Octavox VST, and then load your settings from that preset.
Let me know if this helps out, if not we can continue to troubleshoot.
Best,
Tom
