Home Forums Products Stompboxes Harmony algo Reply To: Harmony algo
#144129
markboorman
    brock wrote:
    The Diatonic algorithm is what you want.  Two additional harmonies, with both intervals constrained to scale & key.  Plus a full featured dual delay, with some unique feedback routing.  QuadraVox will give you four additional voices in scale & key.  Both have the same maximum delay time, with QV carving that time into rhythmic patterns [no feedback].  Either one can enhance the doubling illusion with short delays & panning FX.
    Keep in mind that for some of those classic songs, you’re going to need a way to change the harmony intervals, or even the key / scale at certain ponts in the song.  An Aux switch, expression pedal, or MIDI can make those transitions easier, but switching between complementary presets would work.
    Thanks Brock. I run an aux and an exp pedal so should be able to work it out. Any suggestion on which one to get? I can’t see 4 harmony parts being common so the diatonic looks favourite as it has the 2 separate delays.
