Home Forums Products Plug-Ins 2016 stereo room verb compatability Reply To: 2016 stereo room verb compatability
#144447
tlongabaugh
    paulrotondo wrote:
    Hey Tom,
    So I tried scanning for both 64 and 32 bit same resut for both. FL finds the plugin but under status it says error and theres is a question mark under both "bits" and "effect/synth" columns. I uploaded a picture if that helps. Also, yes the most recent Ilok is installed.
    Hope you can help.
    Thanks
    Hi paulrotondo-
    What is the file path you have the 2016 Stereo Room dll saved to? It looks like it's "C:Users/paulr/Downloads/PLUGINS", is that correct? Did you only install the 64-bit version to that location, or both the 64 and 32 bit versions?
    What I would do, is install 2016 Stereo Room to the default locations, and then add the following to your "Plugin Search Paths": "C:Program FilesCommon FilesSteinbergVST2Eventide". Alternatively, you could also install only the 64-bit VST to the custom VST Path you use.
    Let me know if that doesn't do the trick.
    -Tom
