Home Forums Products Stompboxes Can H9 send Midi Thru when using Midi Over Bluetooth? Reply To: Can H9 send Midi Thru when using Midi Over Bluetooth?
#144507
gkellum
    Poppy wrote:
    Is it possible to send MIDI messages via Bluetooth to an H9 with a bluetooth Midi controller. As you said that they are some differences between MIDI and Bluetooth protocol (but it's maybe only for Midi thru/Out:).
    No, not really.  You can take a Bluetooth footswitch like the BlueBoard, connect it to an iOS device, and send it's MIDI program changes to the H9 using the 'Midi Over Bluetooth' feature mentioned above, but you can't connect a Bluetooth footswitch directly to an H9 and send it events directly over Bluetooth.
