Home Forums Products Stompboxes Recommendations please – MIDI Controller for multiple H9s Reply To: Recommendations please – MIDI Controller for multiple H9s
#144679
Chaining a large number of MIDI devices together is not an Eventide issue, or a pedal issue, or a MIDI controller box issue–  it’s a fundamental limitation of the way MIDI signals are usually sent in a chain.  Typically, each device has a optical isolator/coupler to make sure there’s not actually a direct electrical connection from one device to the next.  This can slightly round off the theoretical square-like signals of a MIDI data packet.
Chain enough of these optocouplers together and the integrity of the signal gets to be a problem.  The solution is to use other hardware to send duplicate messages out in parallel and not have so many daisy-chained.
