Home Forums Products Stompboxes Time factor mix Reply To: Time factor mix
#144729
    Note that some presets have delays with feedback controls. These can give 110% feedback which can get loud. Check the settings.
    If it is not the above, can you re-init the unit (middle footswitch and encoder at power up) ? This will delete any user presets. Then connect  guitar-tf-amp with ordinary mono cables. See if this changes anything.
