Home Forums Products Plug-Ins Plugins not loading in Cubase 8 Reply To: Plugins not loading in Cubase 8
#144791
tlongabaugh
    newvisions wrote:
    Nothing – complete silent fail (which is an issue in cubase when the fixed limit of instances impossed on the c-runtime when linked statically is reached, but that is not the case here). And yes I am using the latest version (I just bought the plugins).
    Ok, thanks. I don't know if you've seen, but this seems to be an issue that's affecting a number of Cubase users: https://www.steinberg.net/forums/viewtopic.php?f=226&t=95005. I'll try and look into that more, to see if it is related (though I suspect it is).
    If you try doing this in a blank session, and saving/reopening, does the issue occur? Or is it only in sessions with lots of plug-ins loaded?
    Best,
    Tom
