Home Forums Products Stompboxes H9 Power over Midi soldering solution? Reply To: H9 Power over Midi soldering solution?
#145225
JCR
    rmanulkin wrote:
    That’s wonderful.  Thanks!  Here’s my question – I need the power to be coming from the input.  Does this only work from the output side?
    Only midi outputs can supply midi power! Midi inputs are using opto-couplers to isolate the signal and, because of that, are not capable of supplying midi power.
