Home › Forums › Products › Stompboxes › H9 erratic MIDI behavior › Reply To: H9 erratic MIDI behavior
December 29, 2016 at 2:02 am
#145271
starkjo wrote:
gkellum, and other staff at Eventide, it seems like I have solved the problem. If that’s the case, then the problem was in my end – my MIDI controller (Boss ES-8) sent out MIDI CC message #080 by default on all MIDI channels in conjunction with every MIDI PC message. It was in a submenu on the Boss ES-8 that I hadn’t even discovered. After I turned off the MIDI CC messages, the H9s seem to work great and respond swiftly, without freezing etc. So my fault!
Hey I am occasionally having a similar issue with my H9 and Nemesis. I’m also using a Boss ES5 and have suspected that the issue was with the controller rather than the effects…..
Where is the CC #80 located on the ES8? Is it an “assign” or is it in another menu??
